ls6?
thanks for the info i'll be taking a look as soon as i get a chance. whats the difference between the two if no body minds me asking? i mean aren't they the same 5.7? one have more advantages than the other
Pretty sure the rotating assembly is identical. The only difference is the block casting. It has some revisions for better internal crankcase breathing I know for sure. There are probably some other minor difference as well.
Rockstar
From what I have read it has windows on each end of the block, inside the valley, that you can see the cam through.
I don't know if an LS1 block has those, but I know for sure that an LS6 does.
it has the ls6 block part number. Same as inlet and exhaust manifolds. But for some reason it came from factory with ls1 241 heads.
The following users liked this post:
Shtstr (01-03-2023)
