stock ls1 rod resizing
I just bought a 98 Trans am with an ls1 in it. I bought it not running pulled the motor tore it down. The valve floated hit the piston broke the push rod and that bounced around inside. When I took the rods off I noticed that where they seperate all look like they were snapped instead of machined. Is this normal and if so am I still going to be able to get the rods resized if they need it.
Moderator
To resize them, you just hone them about .002" oversized and call it a day. You don't have to (you actually shouldn't) cut the parting surfaces at all. Clevite makes a bearing thats oversized for these resized rods, pn 1776-P.
