408ci roots blower build
Old 05-13-2011, 08:25 PM
deion82's Avatar
Default 408ci roots blower build
Well i finally bit the bullet and started my build after months of decisions.
It's a 6.0l block bored .030 with the callies speed pak with upgraded i-beam rods and the forged diamond -28 dished pistons.
Should be around 8.5cr
Keith Craft AFR 245 ported heads.
ED Curtis FTI hyd roller cam designed for a 10-71 roots blower.
BDS 10-71 stage 3 blower with billet rotors coming if my intake ever gets done. ha-ha They have been working
on it for about 11 weeks now.
BDS 3 hole bug catcher hat and 16 injector efi setup.
Holley dominator ecu kit coming when that gets in stock with there coil setup and wire harness.
Will post pictures as the build starts.
I powder coated the block chrome looks pretty trick.
Attached Thumbnails 408ci roots blower build-injector-plate-large-.jpg   408ci roots blower build-ls1-thumb-large-.jpg   408ci roots blower build-blower-hat-large-.jpg
Old 05-13-2011, 08:33 PM
deion82's Avatar
I'm still debating on the boost setup. I was thinking seting it up at 10psi and have 12lb and 16lb pulleys sent with for the dyno. The master tuner Mark thinks a 8lb setup and then have 10lb and 12 lb pulleys sent with. i'm sure he will chime in with more details.
I should mention this will be a E-85 engine and shooting for 1,000 -1,200 hp
Old 05-13-2011, 08:40 PM
oakley6575's Avatar
Subscribed for pics and results
Old 05-13-2011, 08:41 PM
deion82's Avatar
What everyone think about setting up the boost to achieve my goals? A here a few pictures of the vehicle also. I know Mark hasn't seen these.
Attached Thumbnails 408ci roots blower build-100_2210-large-.jpg   408ci roots blower build-100_2212-large-.jpg   408ci roots blower build-100_1919-large-.jpg   408ci roots blower build-100_1932-large-.jpg
Old 05-14-2011, 06:07 PM
180ls1's Avatar
cant say ive seen a build like that, looks really awesome. Make sure you take some pictures and post them up for us to enjoy. That truck should be a ton of fun.
