cam and head swap on 5.3
i have a 2000 5.3 and have a set of 243s that is milled 0.30 .i want to run a ls6 cam but dont know if i can use the stock 5.3 valve train rockers ,pushrods etc...and what thickness and brand headgaskets do i need.. thanks
You will need ls6 valve springs to run the cam as stock valve springs are only good for .500 lift. everything else should be good. id replace the lifters and add some aftermarket pushrods. and since the 5.3 has a smaller bore then an ls1 make sure the valves don't hit the block.
