Pulling the trigger tomorrow....on a cam
Old 05-15-2011, 02:17 PM
allout06's Avatar
Default Pulling the trigger tomorrow....on a cam
Well the times come to start piecing together my cam swap. I originally was set on the torquer v3 from Texas speed along with the ls6 oil pump, ls2 timing chain, cam gasket kit w/ longer arp crank bolt ect...but I ran across a cam called "the polluter" from tick performance. It's the same exact kit but it's $100 cheaper. The specs of the polluter are 24x/24x .61x/.61x 112lsa. The v3 is 231/234 .643/.598 111lsa. I've heard both produce awesome power and not just peak numbers. it's a street car only (see sig). Which cam kit would u guys go with? I drive it mainly on the weekends and I want that streetable/usable power and torque. along with the cam I'll b Pickin up a bbk ssi intake since they are $100 more than a used ls6. And I'm sending my throttle body out to be P/P... Im just worried the polluter will b too big and be a turd with in town driving even though I do have 4.10's. I will buy heads later down the road. and I'm purchasing one of these kits tomorrow so custom grind is a no no for me. hope that's enough info. Thanks.
Old 05-15-2011, 02:59 PM
RedRallyeZ's Avatar
I've got the T3 and I've been very happy with it. My car was an A4 until just recently, but since i switched to the M6 it seems like my car is always in the power band. My tune could be a little better, but i'm convinced i made the right choice.
I've also got heads on the car, but I'm very happy with my torque curve.
Old 05-15-2011, 03:33 PM
allout06's Avatar
What are ur supporting mods? I'm on my phone so it doesn't show sigs. does it pull pretty hard. I just don't wanna go too small the first time.
Old 05-15-2011, 03:35 PM
99Bluz28's Avatar
The Polluter cam is far from what most would put on there list of streetable cams, the T3 would be a better choice.
Old 05-15-2011, 03:52 PM
allout06's Avatar
Ok that's what I was thinkin. I just ran across that kit for a good price. Maybe Texas speed can hook me up since tick performance kits are a little cheaper.
Old 05-15-2011, 05:36 PM
RedRallyeZ's Avatar
PRC 5.3L heads, Ls6 intake, LT's, custom ORY, flowmaster, lid, etc.
pulls pretty hard. as i said, I,m not 100% sold on my tune, which is partially because it hasn't been on the dyno since i did the trans swap. but through a poorly designed Y, and an awful flowmaster CB, i put down 384rwhp on a mustang dyno through an unlocked A4. feels like a great streetable cam
Old 05-15-2011, 06:57 PM
allout06's Avatar
Ok kool. I should b lookin in the 400 range then with a m6. I'll probably just stick to my gut and order the v3 tomorrow. I think the price of the kit and their fancy advertising caught my eye lol.
Old 05-15-2011, 07:00 PM
allout06's Avatar
Also it seems u putting out pretty low numbers with having a set of heads....I would think u should b in the 420ish range with heads and a cam on an a4....hmm weird
Old 05-15-2011, 07:11 PM
s346k's Avatar
get some 410s and put that polluter in there. in the words of my hs shop teacher - don't be a *****.
Old 05-15-2011, 07:28 PM
Wildcobra's Avatar
Wow LOL Good shop teacher
Old 05-15-2011, 07:41 PM
allout06's Avatar
Lol funny shop teacher. And I already have 4.10's. I posted that with my mods.
Old 05-15-2011, 08:05 PM
RedRallyeZ's Avatar
Yeah, that's what I thought originally too. Then I talked to a few other people that had been on that dyno and they had lower numbers too. Keep in mind that mine is through a terrible exhaust setup, an UNlocked torque converter and a less than perfect tune. I needed some work to say the least
Old 05-15-2011, 08:12 PM
racerfox's Avatar
my car made 440 rwhp and 408trq with prc 215 heads ls6 intake 36 intake and tsp headers it is a m6 car and it pulled hella hard i made the combo around auto x with a fast i would of hit 450+ easy
Old 05-15-2011, 09:16 PM
allout06's Avatar
Sounds like that dyno is waaaaayy off lol even with a shitty y-pipe and a bad tune, i wouldnt think it would hinder you almost 50hp. i could be wrong though. ill call up texas speed tomorrow and see what they can do for me since tick's price is a little less money for the same exact kit, just different cam obviously. im excited to get it done tryin to decide if i should pick up the chris1313 ram air and maybe a UD pulley, dunno if either are worth the $$ though.
those are the heads ill probably end up buying here in a few months... but ill b running the BBK ssi intake (i may throw a 150 shot on it later on) but for $100 more i get a better looking intake and a claimed horsepower increase with the bbk over the ls6...well see...so hopefully i b above the 450hp then or right at it
got ur pm btw, replied to it
Old 05-15-2011, 10:28 PM
racerfox's Avatar
wrong bbk heats soaks dude
Old 05-16-2011, 01:01 AM
hfthe3rd's Avatar
Bbk doesn't...there's a forum all about it.
Old 05-16-2011, 01:10 AM
racerfox's Avatar
spend the extra 3 to 4 hundred for a fast dude it has ben proven the best power making intake
Old 05-16-2011, 02:17 AM
01ssreda4's Avatar
Torquer V3 out of the 2 choices.
Old 05-16-2011, 02:41 AM
Johnnystock's Avatar
with the 4:10 the Polluter wouldnt be too bad on the street with the right tune. But the powerband would be crazy with that gear and a T3..
Old 05-16-2011, 03:38 AM
SSmoked1's Avatar
The polluter runs good on the street and can seem mild depending on the tune. If it's not a DD go big. You already have the gear for it too. Nothing like doing all that work and wishing you went bigger like a lot do. Then again you could also wish you didn't go so big.
