T-Rex installation has begun
Old 02-23-2004, 11:01 PM
SMOKIN01TA's Avatar
Default T-Rex installation has begun
well im halfway throught doing the spring, seat,seal,retainer swap.
this crap takes freakin forever and is a pita. those little spring locks+greasy hands equal droping stuff
just thought id let yall know that the first installation has begun, hopefully i can post some results the end of the week.
oh yea, i also need a break.
Old 02-23-2004, 11:03 PM
VetteCrazy's Avatar
Awsome choice!!!
Keep us updated!!
Old 02-23-2004, 11:06 PM
wannabels1's Avatar
Originally Posted by SMOKIN01TA
equal droping stuff
lol just make sure its not the soap
just kidding, good luck with the install
Old 02-23-2004, 11:11 PM
SMOKIN01TA's Avatar
this is definatly the first decent post you have made.
cograts on not insulting anyone.
Old 02-23-2004, 11:19 PM
SSean's Avatar
lol
keep us posts how everything turns out. You have ls1edit, or plan to make it to a shop pretty soon? I would be intrested to see how it acts pre-tune
Old 02-23-2004, 11:38 PM
I can shift faster than you.
Jason99T/A's Avatar
Sounds good Rodney! Bring the car by the shop when you are done with the spring swap and I'll install the cam for you.
Old 02-23-2004, 11:50 PM
SMOKIN01TA's Avatar
Originally Posted by Arctic98Z
lol
thunder will tune it as soon as my damn headers come in from jet hot. i would love to get a idle clip before i tune it. should sound bad ***. and since i will drive it there(its only 1 mile) ill let yall know how it drives before the tune with the 4.10's
Old 02-23-2004, 11:52 PM
SMOKIN01TA's Avatar
Originally Posted by Jason99T/A
Sounds good Rodney! Bring the car by the shop when you are done with you are done with the spring swap and I'll install the cam for you.
might just do that. then you bring you car buy so we can get that 12bolt in and get if finished before next month.
Old 02-24-2004, 02:21 AM
STF veteran / 10 second club
x phantom x's Avatar
I don't get it ... why wouldn't you just put the cam in while the car is already apart? The cam is the simple part, it is the springs and seats, etc that take forever.
Old 02-24-2004, 05:57 AM
dazman's Avatar
it's a joke.... the springs are hell and jason knew it so he was being sarcastic
mike
Old 02-24-2004, 06:59 AM
Automag928's Avatar
Cool deal! Keep us updated!
Old 02-24-2004, 11:28 AM
SMOKIN01TA's Avatar
dazman, nice try, but no. the reason the cam isnt going in is because we are going to get a baseline with the stock cam then slap the other one in and try it out. the reason i havent been able to basline it is because the headers are still not back from jet hot and im pressed for time to get this thing finished.
think of it this way. it may loose 3 or 4 rwhp with the upgraded valvetrain for the baseline, but we are doing a true cam only swap still have to install my roll cage, new rims and tires. new gears,tach and other crap then have a chance to practice atleast once before the shootout.
Old 02-24-2004, 11:31 AM
SMOKIN01TA's Avatar
just for a laugh, it took me over 4 hrs to change all that crap last night.
might be because i forgot a valve seal and had to figure out which one it was.
Old 02-24-2004, 12:01 PM
383ss's Avatar
what springs are you using?
Old 02-24-2004, 12:13 PM
dazman's Avatar
which valve spring compressor where you useing???? was it hard?? i have done a set of comp 918s and it sucked, i can only imagine what some duals are like!~
mike
Old 02-24-2004, 12:27 PM
SMOKIN01TA's Avatar
i am using the crane duals with .030 shims, new seats, seals and tit. retainers. they almost double seat pressure.
dazman,
i used the more performance tool that thunder sells. it works excelent. you really need a 1/2 drive long ratchet with a reducer to 3/8 to give you enough leverage to comfortably hold that spring compressed while trying to get the lock in. or a second person would have been nice.
Old 02-24-2004, 01:14 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
SMOKIN,
How did you check the Piston to Valve clearance?
Old 02-24-2004, 01:33 PM
SMOKIN01TA's Avatar
Originally Posted by SouthFL.02.SS
SMOKIN,
jason had checked it on a stock short block with a 241 casting head so i knew it would be ok. we used the spring machine to find out the coil bind and open height to see what size shim is the best withount binding.used a valve spring heigh micrometer to measure the exact height that would work with th valve closed. the differnce was just right for a .028 shim while still leaving room for coil bind. we assembled it on a stock 241 head yesterday afternoon. This seemed to be the best setup for it.
if you go with this cam. just get the exact stuff i have listed to avoid all questions. if you go with the comp springs the shims may or maynot be the same.
to answer someones next question i can see coming. i dont know if you have to run shims, i dont think jason is, but due to the lift of the cam, i would do it for extra safety. i think it will be recomended.
Old 02-24-2004, 02:24 PM
pdd
pdd's Avatar
Originally Posted by VetteCrazy
Awsome choice!!!
Keep us updated!!
i agree
Old 02-25-2004, 09:47 PM
SMOKIN01TA's Avatar
well the car is once again down to a driver seat only
im done with putting all the performance parts back on it.
now everyone is waiting on jet hot. its going on 3 weeks.
anticipation is killin me. guess i could start on the monkey bars now.
btw, if you cant tell, i have decided not to sell the car.
hopefully we can get the ball rolling so i can get some track times before the shootout.
