Cam size question
Old 05-19-2011, 12:23 AM
Evilution's Avatar
Question Cam size question
how big can you go with out fly cutting the pistons on a stock short block? i know there are variables when installing the cam but as a rule whats a safe bet as far as max lift and duration goes. reason i am asking is i have a track only car thats stock internal at the moment but I want to get a cam soon. anyway any info would be helpful
Old 05-19-2011, 01:08 AM
01ssreda4's Avatar
Probably a TRex from Thunder or an MS3 or 4 from TSP. Those are pretty big but designed to work with a stock long-block. You have to turn the rpm to get the power from those cams
Old 05-19-2011, 05:56 AM
ripfirebird94's Avatar
I went with the 233/239 camshaft from TSP with a 112lsa, its fricken nasty man. sounds amazing to with true duals...
heres a clip
http://www.youtube.com/watch?v=W-ig2-niV4g
Old 05-20-2011, 01:31 AM
Evilution's Avatar
sounds nice man! i didnt know the trex would clear. thanks for the info guys!
Old 05-20-2011, 01:34 AM
WSUShocker's Avatar
wow that sound good
Old 05-20-2011, 02:24 AM
01ssreda4's Avatar
Originally Posted by WSUShocker
wow that sound good
Yep, like a farm truck haulin hay...
Nice rev during "first start up" i.e. no tune. You should hear my cam with a 550 in gear idle But if you idled it up to 850 or so it would prolly push through that stock stall eh?
