loud ticking from passenger side after cam..
Old 05-21-2011, 12:47 AM
1Psycho's Avatar
Default loud ticking from passenger side after cam..
Got the cam in, got the car running, sounds badass! But I have another problem. Yes I know theres gonna be ticking after but theres a bit of a louder ticking on the passenger side. Goes faster when it's revved up a bit. Oil pressure is where it should be, car is kinda hesitant with the throttle and idle is a little iffy but it idles alright. What do you guys think? Exhaust leak, lifter tick, valve hitting? any ideas? I pulled the passenger valve cover right off to check for a loose rocker arm and that's not the case. Can't really hear it from inside the car but I know it's there so it's sketching me out. Do I take it for a little drive or check some stuff or any ideas?
Old 05-21-2011, 01:03 AM
1Psycho's Avatar
Let me add too that before the cam swap there was a slight ticking from the passenger side too. Remembering that I think exhaust leak or lifter tick?? I'm sketched out to drive it, just dont want it to be a valve or something and going kaboom
Old 05-21-2011, 01:30 AM
ls1 1990 VN's Avatar
Get a real long screw driver, stick it on different places with your ear against the handle and listen for the sound. Stethoscope is better.
Old 05-21-2011, 09:49 AM
1Psycho's Avatar
It's coming from the back of the passenger side, either 6 or 8th cylinder...that's right where it was coming from before the swap. Could this just be an exhaust leak or lifter from before that just got louder?
Old 05-21-2011, 02:18 PM
1Psycho's Avatar
Just took it for a little drive around the block a few times to get it hot and see how it was. It was doing alright until it got up to temp, then it didn't want to idle at all so I pulled it back in, killed it, and popped the hood and there was a little bit of smoke but it dissipated after like a minute. Bad??
Old 05-21-2011, 02:34 PM
hotrodth's Avatar
You prob have a bad lifter. Then when you put in a bigger cam it made it collapse all the way.
Old 05-21-2011, 02:54 PM
1Psycho's Avatar
if it is a bad lifter, is it gonna be bad if I run it a little?
Old 05-21-2011, 03:01 PM
sabersaw30's Avatar
You need a tune for a good idle and it not to smoke.not sure on The ticking.
1Psycho's Avatar
Before the start I pushed on all the backs of the rocker arms and nothing gave so I thought all the lifters were good. Could this just be piston slap amplified? There's been a little tick there as long as I've had the car, got noticable with headers and now loud.
Old 05-21-2011, 03:20 PM
1Psycho's Avatar
So is the smoke oil on enigne parts and in the tune? Dunno how that would cause it to smoke though just from needing a tune..
Old 05-21-2011, 05:13 PM
1Psycho's Avatar
Just went to start it up and take it for a small drive and when I started it, it make like a chirp and then ran but a plume of smoke came from the exhaust..HELP!!
Old 06-06-2012, 12:09 AM
19Nova62's Avatar
Any Solutions? Brought back from the dead. Same symptoms!
Old 06-09-2012, 02:39 AM
1Psycho's Avatar
Do you still have AIR/EGR? I did and that was leaking which is what it was..deleted that and got a tune, all gone!
Old 06-09-2012, 06:28 AM
baxsom's Avatar
what color smoke?
Old 06-09-2012, 06:39 AM
GMtechmatt's Avatar
if u want tom save urself the trouble pull valve conver and check clearance with a feeler gauge and if that is good it might be a lifter. ls1 are also good for have carbon build up on the pistons that cause a loud tick when carbon is heavy. get a can of BG44K and run it through the fuel system
Old 06-11-2012, 08:39 AM
1Psycho's Avatar
was just a little white smoke
Quick Reply: loud ticking from passenger side after cam..
