Only one side of engine running?
Old 05-21-2011, 03:30 PM
Strobes's Avatar
Default Only one side of engine running?
My dad and I just swapped in a 98 LS1 into a 98 previously v6 bird. We thought everything was good to go until we tested the coils on the passenger side and the whole side seems to not be getting any spark?
Could it be just a blown fuse? Bad ECM? Your thoughts? This seems to be our last major hiccup and I just want it on the road!
Old 05-21-2011, 05:18 PM
darknessxyz's Avatar
From what I know, when you swap a V8 into a V6 F-body, you'll need to replace the WHOLE wiring system. That includes the engine wiring harness and body wiring harness. Technically, they're two different car. If you've V8 engine harness and PCM, then I guess you guys just missing something didn't hook up right.
Old 05-21-2011, 05:51 PM
Strobes's Avatar
Yeah we have all that hooked up from the same engine...we're starting to think it's a bad computer. It couldn't be just all 4 coils went bad on that side, although I wish it were that easy
Old 05-21-2011, 06:01 PM
Just swap one of the non-working coil to the working side and see what happen. It could be possible that one bank all coils doesn't work due to wiring problem. But all coils fail at the same time is rare.
Old 05-21-2011, 06:19 PM
Darkman's Avatar
Each bank of ignition coils has a separate ground. Double check the grounds. (I do not know about your application but on an LS6 they are on the back of each cylinder head).
Old 05-21-2011, 08:50 PM
crainholio's Avatar
And to add to Darkman's point, each bank of coils/injectors has a separate 12VDC ignition-switched fused feed in the factory wiring diagram.
After you've confirmed the grounds are firmly attached, start at your two fuses w/ a test light or meter and work your way up to the coil connector.
Old 05-22-2011, 02:25 AM
TurbopigB4C's Avatar
You just need to find what the four that are not working have in common on the wiring diagram. Missing and bad grounds can cause havoc.
Old 05-22-2011, 08:27 PM
KILLER-LS1's Avatar
you need to add a 12v ignition wire to the other bank. thats your problem... I swapped an LS1 into my friends camaro and we had to do that. its mandatory that you do this when making the LS1 swap
Old 05-22-2011, 11:38 PM
Makes sense because of how the coil packs plug in. It has one big connector with four wires and then has a harness going into each coil.
Old 05-23-2011, 09:23 PM
Strobes's Avatar
Thanks all for your input. Would anyone be able to post a schematic of the ignition system including the PCM ? It's a distributorless system that is NOT in the Chiltons guide.
Old 05-24-2011, 12:33 AM
chrisfrost's Avatar
Hey , Autozones website should have the wiring diagrams that You need for free . Just click add vehicle then vehicle repair manuals then wiring diagrams. If they don't have it message Me back and I'll see if I can't post My truck diagram which should be basically the same as the Camaro as far as the ignition circuit is concerned . Good luck .
Old 05-24-2011, 08:51 PM
Strobes's Avatar
No luck- they had a link for distributorless, but no picture- like a dead link...
I'd appreciate your trouble if you can post yours...thx
Old 05-24-2011, 11:57 PM
Talk with a service writer / manager at a local dealership and ask nicely for the wiring diagram off SI. Lots of dealerships will do it so that they can hope to get your business for something else. I did it for a few customers at the last dealership I worked at.
Old 05-27-2011, 06:17 PM
Strobes's Avatar
The ignition wire that Killer-LS1 mentioned that was mandatory...where does it come from and where does it connect?
Old 05-27-2011, 07:30 PM
Darkman's Avatar
These are for an LS6.
Attached Thumbnails Only one side of engine running?-119118421.gif   Only one side of engine running?-119118465.gif
Quick Reply: Only one side of engine running?
