ls6/fast top end or ls3 top end?
well im new to posting but hopefully im in the right section. i have a forged 370 that i recently had built and i first ran it wit stock 317heads and it ran really strong just broke it in with these heads, then i bought a set of prc 2.5 heads and a set of 42lb injectors and installed them now the motor feels alot weaker and doesnt respond as good as it did wit the stock heads and injector. the car is not tuned yet but i wanted to see if i should sell the top end and buy an ls3 topend which would be much cheaper and probly same power before i spend money on tune. just wanted to know which would perform better thanks
LS3 setups have more power potential and easier to make power with.
Thats a huge injector for what you have and like the others said, tune is mandatory, yesterday. Put the stock injectors back on until its tuned. You have way more inj than you need.
pull the fuse on the fuel pump and do a compression or leak down check.it don't take long to wipe out the cylinder hones.the extra gas will wash away the oil film allowing metal to metal contact.
