What Size Cam on a 383 built..?
Hey Guys.. Am Building my 99 ss Am doing a 383 stroker.. Like the title says.. Anyone with a good cam set up..? What size..? Am thinking of going with the ms3.. or ms4..? kit.. Thanx.. On my 346 i was runing a American Custom Cam 288/225 intake 296/233 exhaust 569/596 lift on a 114. I have 853's heads with Mild port. I was Dyno at 406 rwhp. with bolt-ons as well.
Thanx!
BTW..!! Heres a video of my car getting dyno a 1yr, after the Heads & Cam install At 09'' L.A. Invasion at CMS..
http://www.youtube.com/watch?v=pdUnTDJ9YTU
Thanx!
Thanx Guys.. Am gonna find out What is the flow on the heads Cause at this point it does matter on the New Cam Specs.. right..? Like i said they have a Mild port.. I think is a Stage 2.. But really dont know the flow.. or cc's. What would be a good size head to run on a 383..? Am sure my 853's are pretty old for the 383.. Even if their ported..?? Can i make this flow More (better) with more work on them..? Sorry Guys Am not to familiar with Thiss.. I will appreciate any kind of advice.. Thanx!!
you in Cali?what about emissions?get a custom EPS cam to work with your heads.if you want to step up to better flowing heads look at some trick flow 220 ,or some TSP prc 215/227 heads if its in your budget.
Yes.. Am in L.A. But Really Could get away with that whole emissions FOR NOW.. LOL.. I Will Look Into TryN To Get Some Better flowing Heads.. Definitely Not in my budget since i didnt think i would be needing them.. Maybe if i can get a set of them used or really cheap.. i was thinking my ported 853s would be good for now.. I mean if the h.p. difference is not by a whole lot.. But Then again i wouldnt know.. They say 383ci wont give you a whole lot h.p. maybe 10-15 h.p. gain.. That is all in ure Heads & Cam..?
Came across These.. idk.. if they are any good.. Maybe the brand..? Never heard of it.. Can anybody know by the specs listed if the cc's or flow are any good..? What do you guys think..??
http://cgi.ebay.com/ebaymotors/CNC-L...Q5fAccessories
LS1TECH Sponsor
are you planning on upgrading the heads? are you planning on throwing a fast manifold on it? what kind of power band are you looking for?, answer all these questions and i can help you out with a cam... shoot me a pm, or talk to me at LA invasion on sunday at the track
LS1TECH Sponsor
thats because you dont do this for a living, so your opinion is just that and uneducated opinion... even if peak HP numbers are the same between a 346 and 383, the 383 with walk all over the 346 just because of the under the curve power, and torque... now this is my opinion...
no **** the 383 will make better power if the setup is optimized. Im just stating assuming if he had a few thousand to spend that he would be better off spending it on good heads and intake to match to a new cam instead of having a 383 with an ls6 intake and 853 heads with an unknown port with the new cam if the shortblock is still good.
the ls6 intake and his heads will probably be the bigger restriction here not the cubic inches of his engine. Is that so hard to understand or do you just like to call me out and make yourself look like a *****?
Personally i would probably go with a iron 370 if i was on a budget anyways over the 383 ls1.
