LSX bowtie vs ERL sleeved aluminum blocks
Again which one would be better for the long run for a turbo setup. Jus want to get a better peace of mind before I actually make a decision on the setup I got with.
ERL blocks have 6 bolt per cyl. and billet mains as well.. just dont want to buy something and have the doubt in my mind.. (f*k i should've gotten the other).. i dont want to end up saying that.
Moderator
ERL does great work, but the Superdeck is just an OEM block disguised as a race block.
I appreciate your opinion but I think you're mis-informed about this. We have been testing and improving our Superdeck system now for 5 to 6 years in the harshest environments from sand rails to 2000 +hp drag cars and have had GREAT success.
Yes we use stock castings but these "OEM" cast GM blocks are a great platform for ERL to work their magic. I don't know how you can say it's just an OEM block disguised as a race block. It's quite clear from our website and from many articles written about our Superdeck system that it's anything but OEM and I can tell you that MANY big boost, high horsepower guys use our product with great success and have for years. You can't push 2000 hp through an "OEM block intended for a passenger car", but after we are done with it you can and do.
The LSX block has it's purpose and so does ours. In the end after you spend the money to get either one ready for a big application it all comes down to weight and allot of it. 140 lbs in most cases extra on the nose of the car.
One of the nice things about our ERL Superdeck I product is that anyone with an aluminum LS core can send it in and have it transformed from an OEM 300 - 400 hp bottom end to a 2000 + hp if they want and everything in between. There is no need to purchase an aftermarket one when their core will do everything they need it to do after sending it to ERL.
Moderator
However, I do not think an OEM block is comparable to a race block no matter how much you weld on or machine into it. It's still an OEM passenger car block. Sure the ERL Superdeck has proven capable of 2000hp, and so has the LSX Bowtie block, but that is irrelevant. The topic is which is better in the long run. Unless I am misinformed and you can get the ERL Superdeck with a 60mm cam, .937" lifters, and priority main oiling, my choice is the Bowtie block.
im really leaning towards ERL.. either way i go, if anything happens im gonna say the same thing.. should've gone the other route.. i've seen LSX's blow a little too much.. so wanna try something different..
i would go with ERL, i mean for example, if you to got the boost section you will find plenty of people on here running stock casting 5.7-6.2 blocks with forged internals and running 1000+ hp. there is no reason to think that the block itself would be the weak point in any matter. the main reason i have seen an LS block go is from parts breaking off (ie broken cylinder 7 ring lands, bent valves due to not enough PTV clearance, insignificant oiling, overheating). so the block itself even in stock form is a masterpiece just in itself, and ERL just took a great thing and made it AWESOME! if you are worried about the oiling, then get a dry sump LS7 based system with an 8 quart oil pan, otherwise their blocks are awesome in every way. unless you are pushing like 20+psi of boost, 6 head bolts are not necessary
