how much can you mill heads?
i have a set of used afr heads ive read they have a .750 deck hieght.i measured mine with a measuring tape(knowing they had been milled)and from the mark thats on the heads to the bottom is 3/8" or .375 i beleive.was wondering if this is to much,if i need valve cut pistons.
i have a bone stock 02 ta i havent choosen a cam yet but have a fast 92/ported by tony mamo and a nw 92 TB,and pacesetter 1 3/4 LTs to put on with these heads any suggestions would deffenatly be appreciated.
not a mech. i do paint n body so excuse my stupidness.
thanks mike
thanks mike
Have the chambers CC'd. That will tell you how much they have been milled, and you will need to know what your compression ratio is, to accurately choose a cam.. Just about any automotive machine shop can do this, and you could even buy the tools yourself if you wanted to learn.
