AI valve/mill job 241s or stock/milled 243s?
I have about 800 to spend TOTAL, including gaskets and bolts. What would be better: 241s sent off to AI for their $500 valve and mill job or a set 0f stock 243s milled .020"? I go the 241 route, they will be milled as much as possible without any PTV issues. I would like to get to 57cc. My cam is a Spartan-spec'd 228/232 .581 .588 112+3. Thanks!
Believe me, I would LOVE to. But that means my car will be down even longer and I don't want to spend money like that until I do a FULL build.
What would make the car FASTER? I'm not concerned about a peak number. The 241s with a valve job and milled to 57cc or stock 243s milled .020"?
what would 241s with a good valve job flow compared to 243/799s?the 243 has a better port and flows 20 cfm better stock.243s ($400) good valve job($150) can flow close to 260 cfm..is there a good engine shop near you?save the cost and time of shipping.
OWN3D BY MY PROF!
You could also have your 806 heads ported. The only difference between them and 241s besides the valve covers is the casting process. Once you start porting it is no longer a factor. That would save you the money of having to buy the 241 heads and new valve covers.
What cc are stock 241s? Roughly how much can I mill them to and maintain PTV clearance? For the price difference of buying the 243s and having them shaved (or not much more anyway), I can just get the 241s CNC'd. Ill ultimately be giving up 10-15 potential ponies, but that is fine. Thanks again for the help, guys!
