need help on what pistons to go with.
Old 06-05-2011, 04:07 AM
tyler ovel's Avatar
Default need help on what pistons to go with.
Well I have a stock ls1 with a mild cam and some patriot 243 ls6 heads, and I'm looking to forge the bottom end to take a good shot of nitrous but don't know exactly what pistons specifications to go with or what they mean such as flat top or dish, _2cc valve relief? And so on...... so if someone could help and explain this a little I would appreciate it. Thanks
Old 06-05-2011, 11:55 AM
oakley6575's Avatar
Where do you want your compression to be at? Will it run on 93?
Old 06-05-2011, 01:15 PM
tyler ovel's Avatar
Ok Well Im running 10.5:1 to 10.8:1 right now and would like to run 10.8:1 or 11.0:1 cuz I do live In calidfornia and I need to pass smog still. And I will be running 91 octain because that's all California sells at the pump lol.
Old 06-06-2011, 02:37 AM
PREDATOR-Z's Avatar
WISECO 2cc valve relief with nitrous rings. You'll have to hone to 3.903
Old 06-06-2011, 08:47 AM
mark21742's Avatar
Is the hone the reason most forged blocks are considered 347s instead of 346?
Old 06-06-2011, 09:28 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
Yes the hone will pick you up an extra cubic inch. I also say Wiseco pistons. They have a 3.903 bore" 3.2cc valve relief piston that comes with a nice steel top ring/napier 2nd that can handle a lot of nitrous. Pair it up with a nice rod and an ARP main stud kit and you should be good to go.
Old 06-06-2011, 10:33 AM
tyler ovel's Avatar
Hey thanks guys. Now do you know if I have to buy the rings separate or do they come with the pistons. Thanks
Old 06-06-2011, 10:49 AM
The rings come with the Wiseco pistons now, comes as a package deal.
Old 06-06-2011, 01:35 PM
tyler ovel's Avatar
so what is the difference between a -2cc valve relief and a -3.2cc?
Old 06-06-2011, 02:26 PM
-3.2cc is just a little bit larger of a relief, which results in a little less compression. But you have all the room you need to mill the heads and get it back.
Old 06-06-2011, 04:12 PM
tyler ovel's Avatar
ok well I already have 59cc heads and don't really want to mill the heads so would -2cc valve relief get me to 10.8-1 or 11.0-1 compression with 59cc heads? Thanks again for the info
Old 06-06-2011, 04:14 PM
oakley6575's Avatar
Use a compression calculator online somewhere. Just input your exact specs and it will give you your static compression.
Old 06-06-2011, 04:44 PM
With a stock thickness gasket you will be at 10.84:1. This is with a 59cc chamber in the heads and a -3.2cc valve relief in the pistons.
Old 06-06-2011, 05:40 PM
tyler ovel's Avatar
Thank you very much
