Pushrods?
LS1TECH & Trucks Sponsor
Were the heads milled at all? Have you changed lifters? If this stuff is still stock more then likely you can stick with the stock push rod length. If the heads were milled or your lifters were changed its probably best to just measure the length to make sure you get the right ones. You can get push rod length checkers for about $20.
