Port matching to intake - how and why?
Before the days of silicon gaskets and plastic intake manifolds port matching was easy. Buy a gasket, place it on a couple of studs, spray intake port flange with black paint, grind away to match.
How can I do this with my 243's/LS6 intake? Does anyone sell paper/card gaskets for these engines?
The heads will be off the motor anyway (it's a vortec getting an upgrade) so the work will be easier to get at. Is it worth doing a bit of mild cleaning up in the port, mostly between where the machining ends and the casting carries on?
Even if it only adds a few horses or 1/2 a mpg I don't mind making some effort.
I have often wondered this same thing. I know how its dont on the FAST intake because of its 3 piece design but on an ls1 or 6 intake Im not sure. I know I have seen a full paper gasket intake set before but it might be for one of the metaal intakes. I bet that would work if you could figure out where to get them.
A nice peice of fresh white poster board will go a long way.
Pull your "O" ring gaskets out of the intake and lay a peice of poster board on the gasket area....take your dirty fingers and rub all around the port areas and bolt holes....works just like a graphite rubbing .
Take a Sharp razor blade and carefully cut out the rubbed pattern and BAM! you have a perfect templet .
Lay your cut out poster board on the head, line up the ports and bolt holes then spray some black paint on the head and you can start grinding.
I use poster board for fabbing up everything I build...its easier to cut/ tape paper over and over than it is to grind, cut and reweld metal over and over to get the right shape
Very helpful, I'll get a pack of scalpel blades and give it a go next week.
It might only net a few hp but for a few hours work, why not, especially after I have done the easy stuff. It's either $$ or time, I only have time
