oil pump part numbers?
Old 07-01-2011, 08:04 AM
TermnEatr's Avatar
Default oil pump part numbers?
pn#12556436
how can I tell if I have the 01 plus pump cause I've heard all the ls pumps have this same pn#
Old 07-01-2011, 08:56 AM
MM98's Avatar
Might double check your part#.. Im showing the oldest part# to be 12556434... That was the # back in 99'... They have since changed to 12586665, which is all that is used from GM on the 4.8, 5.3 exc LC9 & LS4, 6.0 exc L76, 5.7(LS1 & LS6) & 6.2's exc L99 & L92
Old 07-01-2011, 08:51 PM
TermnEatr's Avatar
weirddd on the ls1 how to write up he is showing a brand new ls6 pump with the same pn as mine
Old 07-01-2011, 08:54 PM
TermnEatr's Avatar
also found a thread a guy stating the pn you just listed on the box but the pn I listed is actually on the pump.... I'm confused
Old 07-01-2011, 09:06 PM
02TransAm/Batmobile's Avatar
Those articles were written years ago, so the part number might be outdated. Are you looking to replace your oil pump? If so, I've been hearing nothing but good things about the Melling 10296.
Old 07-01-2011, 09:21 PM
Darkman's Avatar
Ditto on the current LS6 part number of 12586665.
I have a Melling 10296 and it works well, but it would requires clearancing work whenever it is used in conjunction with a double-roller chain.
Old 07-01-2011, 09:24 PM
TermnEatr's Avatar
I'm running the stock timing chain I have good faith in it and haven't heard really any bad things of it. So the mellingwill clear fine with it correct?
Old 07-01-2011, 09:44 PM
Yep, cheapest place to purchase a Melling Oil Pump is through New Era Performance Parts for 104.99 plus 10.95 shipping. Everywhere else it's 139.99-159.99 plus shipping.
http://www.neweraperformanceparts.co...mart&Itemid=54
Click on part number 10296.
Old 07-01-2011, 09:47 PM
Darkman's Avatar
You should consider an LS2 chain - not all that expensive and stouter than LS1.
Old 07-02-2011, 02:49 PM
TermnEatr's Avatar
where can I pick up a ls2 chain.... Also I've never installed a timing chain either is it hard what's involed?
Old 07-02-2011, 02:51 PM
TermnEatr's Avatar
also what's the diff between the two mellings pn m295 and m296
Old 07-02-2011, 08:46 PM
Darkman's Avatar
LS2 Timing Chain can be had at Texas Speed or Thunder Racing. Once the oil pump is off the timing chain chane is not difficult.
A melling M295 is the OE Replacement as opposed to the high performance 10296. The 10296 is a high volume pump and comes with two springs to allow the selection of standard pressure or high pressure (+10 psi). An M296 is a Melling pump for Chrysler engines.
Old 07-02-2011, 08:57 PM
TermnEatr's Avatar
at what point would be the need for plus 10 psi of oil pressure over the the regular melling?
Old 07-02-2011, 09:17 PM
Darkman's Avatar
I do not know - perhaps it helps if you are running an external oil cooler; or perhaps there instances where the higher pressure is beneficial with certain bearing clearances. I installed my with standard pressure spring. I wanted the added volume which comes with the 10296.
Old 07-03-2011, 04:58 PM
TermnEatr's Avatar
ok thanks man
Old 07-06-2011, 06:47 PM
TermnEatr's Avatar
wtf i ordered the oil pump and checked the option for the m296 and they sent me the 10295 pump!
Old 07-06-2011, 07:11 PM
Darkman's Avatar
Since the "m296 option" would involve a pump for a Chrysler engine (see above) I assume you mean the 10296 option. The 10295 is a standard volume, high pressure pump.
Old 07-07-2011, 09:41 AM
TermnEatr's Avatar
it says m296 for ls1 and ls2 engines I figured since they had a m295 and a m296 it was the 10296 and the other the 10295 they sent me.
Old 07-07-2011, 10:25 AM
TermnEatr's Avatar
just talked to new era and they said that is the check off for the 10296 and there computers must have glitched cause it is not showing the checked boxes on the invoices he said it's actually 25 dollars more than the 10295 and to send it back and he will cover shipping I just gotta pay the diff
Old 07-09-2011, 03:09 AM
Oh man, sorry about that. I feel partly to blame since I linked you to it.
Quick Reply: oil pump part numbers?
