heads/cam no water/coolant everywhere!!!
i just finished up (or thought i had ) my heads cam install...
i start putting water in the radiator and water is running out from underneath the car!
I can't think of where it is coming from, honestly...i moved over the blockoff caps on the back of my stock heads to my pp 5.3's during the swap...they are on there...
it looks like the water is running from the back of the motor/front of the tranny, but i cant tell where its coming from
the car has not yet been started, so how can water even run into the motor since the thermostat isnt open?
anyone have any ideas? all my coolant hoses are hooked up right...
there an no coolant lines running through the intake or anything else...i have no idea...i wouldnt think possible that it would just be running out of the heads through the gasket? those suckers are on there tight...
im right now...and tired
I can shift faster than you.
Did you put the coolant plugs back in? There should have been one of the passenger head by the #8 spark plug, the coolant temp sensor by the #1 spark plug, and the two coolant plugs on the top of the cylinder heads at the rear of the motor (plugs for the coolant crossover tubes).
the temp sensor is in...
im not sure i even looked...could there be no plugs in my 5.3 stage 2 heads?
There should be a plug by the #8 sparkplug that needs to be installed.
plug? a bolt?
the 4 main plugs were on the heads...
4 main plugs
2 on the top of the heads i moved over
so there is one more plug by the #8? is it a bolt?
it's official...my friends didnt put in the other plug before they gave me the head to put on...
i just looked my stock heads...plug is still in there...
Originally Posted by mikemodano9c
plug? a bolt?
4 main plugs
4 main plugs
