OIL pumping out of turbo feed but no oil pressure???
i have a brand new 370, i have the oils un hooked and fuel pump fuse out, while cranking the engine over several long times it wont build oil pressure, but will pump oil out the turbo feed line??
yeah without it running, and i have a 5.3 truck and when i un hook the coils and fuel pump fuse it build 40 psi.
When other friends have done the same to their engines they all built pressure
do you really think it will eventually build pressure? i was starting to lean towards the back oil plug might not be in place, i no for sure i have the front one but never checked the rear....a few moths ago my buddie ran into the same problem and it was the oil plugs, i just dont want to pull the trans and flex plate if i dont have to
Pressure is resistance to movement....I had this same dilemma with an old
472 caddy, it pushed out a 9/16 plug in the lifter valley. My money is on the
dumbell....sorry
Correction....I just checked my ls book and if your filter is full and since the
turbo feed line is spewwing it sounds like the barbell is in, however it does
say to JB weld the front welsh plug next to the oil pump for added security
or else the pressure will be nill. Maybe you can pull the H2O pump and cover
bolts to get a peek while cranking.
dumbell....sorry
thanks guys. pulled the tranny to find the barbell in, put a gauge in turbo feed hole and cranked it about 1 1/2 min and finally got 50psi!!!!! guess i just needed to crank longer lol. sucks i pulled the trans for no reason
