compression test lq4
I took a compression reading of 4 random cylinders on my LQ4. Engine warm with throttle blade wide open, I got exactly 165PSI on the 4 cylinders I checked. I checked 1,3,2, and 4. I found it strange that they were all the exact same. Engine has a little over 250K miles on it.
Sorry, i meant to ask if the readings are decent for an LQ4, i couldnt find the specs for the lq4's. Anyway its the harbor freight gauge, it divided the lines and they each should be 5 psi. Either way they couldnt be more than a couple PSI apart if any. Thanks for the quick response!
Restricted User
