Oil Pressure guage twitches
Old 07-07-2011, 04:46 PM
ronsws6's Avatar
Default Oil Pressure guage twitches
I have a video link below that shows what it does. 9 months and 6k on a new build 2000 LS1. Already replaced the sensor and it seems a little better but you can see for yourself. It's scaring the crap out of me.
Ideas?
http://youtu.be/RugzQE8zGOQ
Old 07-07-2011, 04:48 PM
Darkman's Avatar
Clean your grounds starting with the negative battery post and including the grounding points on the back of the heads - star washers are your friend.
Old 07-07-2011, 04:54 PM
OnyxY2KSS's Avatar
get a mechanical gauge.
Old 07-08-2011, 10:58 AM
ronsws6's Avatar
Thanks for the replies. I will definitely check the grounds. I was scared I had an oil pump failure. I've been afraid to even start the car
Old 07-08-2011, 04:28 PM
trey1010's Avatar
Mine has done the same thing since i got it 90k miles ago. I recently put in a new ls6 oil pump during my cam swap and it still does the same thing, so i dont think it is the oil pump.
Old 07-08-2011, 08:34 PM
stangtrader's Avatar
Mine has the same thing since I put a new switch in. Grounds would be a good place to start. I'm too lazy now days to look.but now that I got my AC fixed ill look into the cause and let you know my results
Old 07-09-2011, 11:11 AM
slt200mph's Avatar
The factory guage is junk get a aftermarket guage and you will see what your oil pressure really is.
