need size on rod for lifter anti-drop tool
Old 02-29-2004, 05:44 PM
more carbon's Avatar
Default need size on rod for lifter anti-drop tool
on a cam change what size rod do you need to hold up the lifters as the JPR tool does???? looks like 1/4 or 3/8 or 1/2" not sure how this works to stop them from falling into engine??? thks.
Old 02-29-2004, 06:14 PM
99ssleeper's Avatar
I would like to know as well. It looks to me like 1/2", but I dont quite understand how it works. It's milled flat on one side for a reason, but why?
I could make a set for $5...but I dont know what size the rod is or how importsnt the dimensions are...
Old 02-29-2004, 06:23 PM
16 pen magnets is way to much $$$$ , none left over from buying cam anyhow!!!
Old 02-29-2004, 06:47 PM
98SS Blackattack's Avatar
1/4 inch works. Some people use 5/16ths hardwire works better
Do a search, there is alot of info an this
Old 02-29-2004, 07:29 PM
thks,what the heck is hardwire???? and how does it hold the lifter???? thks.
Old 02-29-2004, 08:34 PM
99ssleeper's Avatar
I think he meant hardware
Old 02-29-2004, 09:42 PM
pimpmaro's Avatar
1/8" and wrap it longways in the soft side of velcro tape. ;-)
Old 02-29-2004, 11:15 PM
SS SLP2's Avatar
I think 3/8 shoud do if you use 1/2 I think you will need to grind a flat spot down it to clear as you install then roll about 90 deg I used i/4 but AFTER was told that lifter may slip by the 1/4 rod next time will use 3/8 with velco strip down the rod
Old 03-01-2004, 07:09 AM
Brains's Avatar
5/16" is a perfect fit. I polished mine down with fine emery cloth so it slides in smooth. I put some assembly lube on it as well, that helps.. The way it holds the lifter becomes obvious when you look down that hole -- the notch in the lifter body lines up perfectly with that hole, so when you slide the rods in you are very effectively locking the lifters in place.
Old 03-01-2004, 09:30 AM
OK brains,thks man,cut a couple 5/16" rods about 18 inches and cam install will be bumpless,till you turn the key.
