ATI Crank Pin HELP
Old 07-08-2011, 05:09 PM
99C5Coupe's Avatar
Default ATI Crank Pin HELP
Pinning my crankshaft with ATI pinning kit. Drilled and reamed and pin doesn't want to go in enough. Protruding .29" now and need to get to .093" is something wrong, I hate pounding on the crankshaft. Pin is .50" long.
Old 07-08-2011, 05:48 PM
ss2000's Avatar
As long as you drilled through the threads it should go right in.
Old 07-08-2011, 07:00 PM
vettenuts's Avatar
Take the drill blank end (opposite of the drill end) and see if it penetrates through the hole to the ID where the pulley bolt goes. If it does, try again with the butt end of the ream tool. Wondering if you reamed through deep enough.
Old 07-08-2011, 09:09 PM
99C5Coupe's Avatar
I can't get the pin out now. Okay to grind it down to .093? .22" in the crank.
Old 07-09-2011, 06:28 AM
vettenuts's Avatar
Try to push it out from the inside. Did you pound it in? How deep is it into the crank?
Old 07-09-2011, 08:23 AM
99C5Coupe's Avatar
.22" into crank, pin is .50" long, .28" protruding from crank. Pounded it in. Used vise grips trying to pull it out, no luck. I think grinding it down is my only option. No way to push out from inside. Thanks.
Old 07-09-2011, 04:01 PM
99C5Coupe's Avatar
Took a grinder to it, probem solved. Thanks
