H/C question
H/C question
I am thinking about getting some new cylinder heads and a cam to wake up my trans am. Im pretty much set on the Texas speed 224r cam but im not sure what heads would be best for it. Would the 243 ls6 heads or the 5.3l heads be better?
Depends on goals & budget. It is the machine work applied to them that dictates their performance, longevity, etc. more so than the casting you start out with. Either works, but then again so does the original LS1 casting. Keep in mind your cam selection will dictate what you can do without machining reliefs.
