Ran into a prob with the o2 sensor....
code p0133 bank 1 sensor 1... i bought a upstream bank one sensor and when i got under the car it was to short.. so im wondering do i need a bank 2 sensor with a longer harness? i have lg long tubes on a c5 z... please help
LS1Tech Premium Sponsor
It might have had a Bosch 13111 or equivalent sensor on there, which has a longer wiring harness attached so that you do not have to run an extension.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
im looking at a bank 2 sensor and it is the same as the one on the car so im gonna try it and see what happends. the bank 1 that wasn't long enought had a flat hook up on it this bank 2 is square and fits right in..
