Am I gonna get 50rwhp outta this combo?
With the mods in my sig, I am at 373.5 rwhp N/A.
I am eyeing a set of PRC stage 2.5/5.3 heads for my car, along with a fast
102 intake plus the 102 TB to go with it.
I know a different cam would help a lot, but I want to keep my Hotcam.
Am I being unrealistic to think the above combo will get me there?
423.5 rwhp N/A would be sweet.
Hotcam stays.
With the right tune, you will probable surpass your goal by a little. You could spend a little more & get the PRC 215 aftermarket castings. They are worth around 20whp. over the cnc PRC 5.3's. Then again, so are TFS & AFR versions. Also, PREDATOR-Z is right, AI has a killer cnc program. More expensive, but worth it!
with the heads and cam you mentioned you mite gain 40 hp .the gm hot cam you have is designed for stock heads and stock intake flow..with a newer better cam combined with the combo you mentioned you should meet your goal.
And with the 102 fast shouldn't I be at my goal of 50rwhp?
With the fast 102mm intake you're going to need the fast fuel rails and their valley pan bolts (lower profile to accomodate the fast intake). Definitely go with the 90mm, you're not sacrificing much horsepower and won't have to spend the extra money on the fuel rails. But I believe with any of the fast intakes you should get the valley pan bolts.
If you want a better head, sell your 241s and pick up some 243s and send them to AI. I've heard of people achieving killer numbers with them throughout the power band for the money spent.
