243 heads and yellow valve springs
I'm assuming that all of the yellow valve springs on 243 heads are the LS6 type of springs. What motors got the yellow springs? I know that some truck motors got 243 heads, will they have the yellow springs too? Or are they just used on car motors? Do all 243 castings have the same valve sizes? Trucks too?
243s come on LS6 and some LS2s (e.g. LS2 CTS-V 2006-2007).
Brand GM Performance
Manufacturer's Part Number 12586484
Valve Spring, Beehive, 90 lbs. @ 1.8 in., 295 lbs @ 1.250 in., .570 in. Maximum Lift, LS6/LS2,
Product Line GM Performance LS6 Valve Springs
Number of Springs Per Valve Single
Outside Diameter of Outer Spring (in) 1.290 in.
Coil Bind Height (in) 1.085 in.
Damper Spring Included No
Spring Rate (lbs/in) 375 lbs./in.
Inside Diameter of Outer Spring (in) 0.885 in.
Valve Spring Style Beehive
Coated No
Coated No
My 09 Silverado 5.3 has the 243 heads as well. Not sure on the springs as the valve covers have never been off. The "yellow" springs were updated (still yellow) a few years back due to some of the failures that have occurred and the newer ones that have been coming through are now blue.
The real question is what are you doing with the springs? They likely won't control the valve train with any type of aftermarket cam.
Even with some 243s having the light weight valves, all 243s use intake valves with a 2.00-inch diameter and an 8mm stem as well as an exhaust valves with a 1.50-inch diameter and an 8mm stem.
So the valves, standard and lightweight are interchangeable even though running a mixture of the two types would presumably require different length pushrods.
Certain 243s that originate on some LS6s come with hollow-stem intake valves and exhaust valves that are filled with 78% potassium/22% sodium aka sodium-filled valves. These valves are lighter in weight. They are also slightly longer (0.6mm) than their standard counterparts in order to allow the LS6, which has a smaller base circle cam, to use a standard pushrod. These lightweight valves are getting harder to find and are more expensive.
It is the small cam base circle that will dictate p-rod length (if both on stock lifters), not the length of the valves. Geometry is done via rocker shimming.
If you mixed valves, and one valve was 0.060 longer than the other when using the same cam & rocker arms, then the the pushrod lengths would have to be different to give the same lifter pre-load distance. A longer vavle will decrease the distance from lifter to rocker arm (ie, pushrod length). There are no rocker shims used in a factory stock LSx engine that I know of.
