g5x3 with tfs 215cc?
LS1Tech Premium Sponsor
I'm not sure @ 59cc that will properly clear. You need to check no doubt. The TFS head starts out a good bit larger than 59cc so that will be a healthy chunk of milling.
That's exactly why we built a smaller chamber for the PRC 215 heads. We wanted to get customers a small chamber & maintain stock p/v clearances.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
1 Post
You are right. My mistake. I was thinking X2. Nope a 234 intake will clear easy on a 114 with TFS 215's. 112 might need checking though. I've talked to big shop owners that have said they have done dozens of combos with TFS 59cc heads and G5x3 or similar grinds and never heard of a piston kissing the valve. 234 on the intake is usually max for a 59cc TFS head from what I've been told. You are never guaranteed but when I'm told certain facts Im happy with the relative high percentage of safety I've been told I should have. Im doing a similar combo right now.
stock heads with stock gaskets and a 230/230 on 111+2 I only had .086 on the intake...
for what it's worth I am at 57.5cc with .040 cometic and 239/243 on 111+2 now with tfs 215s and I had -.020...that's right after I flycutted .110 I now have low .09x clearance
