Comp r lifters
Old 07-30-2011, 10:19 PM
silverado2001's Avatar
Default Comp r lifters
Wondering if anyone else was running these I'm getting more top end noise than I'm used too. Not tapping like a dry lifter just a little loud my oil pressure is great and valves are adjusted properly. One of my local shops said that these loggers were just noisy?
Old 07-31-2011, 08:07 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
What lifters, what rockers, and how much preload did you put on the lifters?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-31-2011, 11:35 PM
Unaffliated Racing's Avatar
Werd. Most people don't realize that you have to run adjustable rockers with these bc they only run .002"-.004" preload
Old 08-01-2011, 05:45 PM
GTOdave's Avatar
mine is doing the same thing right now man..read my thread my just posted 3 days ago
https://ls1tech.com/forums/generatio...oken-wing.html
im using Comp R lifters also
Old 08-03-2011, 09:08 PM
Fastdriver1992's Avatar
i ran these lifters with stock rockers and a .010 shim under them and took the car to 6800rpms with no problems going low 11's at 120mph, but it did eventually go with prw shaft rockers
