Afr heads
Afr heads
I just bought a new set of AFR215cc Mongoose Heads. I heard that should you not reuse the head bolts. Also, I am buying the new head gaskets from Fel-Pro and wonder if I need anything else for switch. I am installing a FAST 102mm intake with the heads.
the heads bolts aren't reuseable! they are (torque to yield/one time use) on time use bolts from the factory. if they have been changed for arp bolts those can be reused, not stock thou.
