LS6 connecting rod part number
Was that the correct PN?
I also have to order a CRod and need to be sure that it is the free floating type for the 2004 Z06. Did you order that rod and was it the correct one?
Bumping for a similar question.
I need a set of 11610057 rod bolts,which should be stock for a 2004 LS6 according to a post on performancetrucks.
Are the 11610158 bolts an upgraded factory replacement?
The only reference i've found for the 11610057 pn were on that post,yet when I google "LS6 rod bolt" I get the 11610158 pn that says it is an upgraded replacement at gmpartsdirect.
Can someone set me down the correct road?
Just needing the rod bolts to finish up the shortblock,would rather have the upgraded bolts if possible and they interchange.
