Identify this bolt from photo?
The bolt on the left is the one I pulled from my '02 LS1. The ferrule is snug on the threads.
The one on the right is the one provided by the dealer as the stock replacement. It has a secondary set of threads (or actually ribs, not true threads) and a spacer thing that slides on the smooth part of the shank but does not fit snugly into the connecting rod.
I know there were 2 designs for the connecting rod bolts, the 2nd design being the better one. But I don't know if my existing bolts are first or 2nd design.
Is this the correct factory replacement for an 02 F-body LS1 connecting rod? If so, would this be a 2nd design bolt?
EDIT: Tentative answer--2nd design LS1 bolt on the left, LS6 bolt on the right
As near as I can tell it is the recommended replacement bolt and should be compatible with LS1's.
Sure hope so cuz I just tightened 'em down. And I yanked out all the existing ferrules from the other style bolts.
Oh, ok. So I think what I had was the 2nd design bolts and the new ones I got would be kind of like the 3rd design. I see they are listed for LS6's and all gen III motors, so it must be the LS6 bolt and it has replaced all the predecessors.
Cool, thanks for the reply!
I hope it was the right thing to do to yank out the ferrules...
