tightening ARP rod bolts... torque vs. stretch
Last night I finally got around to putting my pistons & rods into my block (402 stroker, compstar rods w/ARP 2000 bolts). The specs said 75 ftlbs or .0047-.0052" of stretch. At 75ftlbs I was only getting about .004" of stretch. Moving as high as 85 ftlbs didn't provide any additional stretch. I got nervous about going tighter to get the proper stretch. Should I stick with 85 ftlbs or keep reefing on them until I get .005" of stretch?
Stretch is a far better measure of clamping forces provided by the bolt. Unfortunately it is more difficult to measure than torque.
What lube are you using on the ARP bolts - this is very important. Have you run the nuts back off and retorqued and checked stretch? Might have to do this a few times to get torque and stretch in line.
I'm using the goop that was provided with the rods/bolts. I went through 3 tightening/loosening sequences and saw no change in stretch for a given torque value. I'm just concerned that I'm going to wind up at 100 ftlbs or more to get to .005 of stretch.
Stretch is more accurate than torquing. However, people use torque specs all the time with great success. I wouldn't keep wrenching over torque just to hit stretch. If anything, call up ARP's tech line and see what they recommend.
I torqued the rods to 75ft-lb during pre-assembly for my plastigage measurements, which is why I'm a bit gun-shy about going too far beyond that in order to get my stretch to .005"
Well I have a question about this since you brought it up. This is a copy and paste from the latest instruction download from ARP for kit number 234-6301/234-6321 AKA ARP2000
I dont have a stretch gauge and was planning on installing my bolts per these instructions but it seem it takes much more than 45ft lbs to get to the proper stretch. I guess I'll just have to buy a stretch gauge now to verify the proper tq.
Well come to think of it, the both specs are different. 75 ftlbs or .0047-.0052" vs 45 ftlbs .0065-.0070" so I guess I'll be calling ARP to verify the correct stretch.
Part Number: 234-6301 & 234-6321
Application: CHEVY GENIII/LS SERIES SM BLK
Cap Screw without Washer - Rod Bolt Installation
[1] Please check the part-number(s) for your application
against the part-number(s) listed on the instruction sheet.
[2] Make sure there is an adequate chamfer around the bolt
hole on the connecting rod cap to clear the radius under
the head of the bolt.
[3] Use ARP Ultra-Torque Fastener Assembly Lubricant
to lubricate the threads of the bolt and the under head of
the bolt. Then install the bolts and tighten them hand
tight.
[4] ARP recommends using the STRETCH METHOD when
tightening rod bolts. Following the instructions for using a
stretch gauge, Stretch the bolts to . 0065 - . 0070 .
[5] If you do not have a stretch gauge, torque the bolts to
_ 45 ft-lbs using ARP Ultra-Torque Fastener
Assembly Lubricant.
[6] The connecting rods should always be re-sized after new
rod bolts are installed.
[7] A log should be kept on the original non-torqued length
of each bolt. Bolts that have any permanent deformation
or have increased in non-torqued length by more than
.001 in. should be replaced.
If you have any questions or need additional information please
contact us at (805) 339-2200 or by FAX (805) 650-0742
tight.
Assembly Lubricant.
According to the ARP catalog, 234-6402 is an ARP 2000 pro wave and is for a 400ci chevy and its a stud with a nut. Looking at the catalog, we need the head style E while the 234-6302 is an A.
I just called ARP. Their advice was essentially to call Compstar and see what they say.
They did verify, not surprisingly, that the stretch is the measurement that I should be going by... I'm just concerned that the .005" stretch is going to result in a very high torque number.
Update... I called Callies. The tech at Callies agreed that I shouldn't just keep reefing on the bolts to get to the .005" of stretch, and agreed that I should leave them like they are (torqued to 85ft/lbs). He assured me that they will be "fine".
