Critique my Head/Cam Build
I'm trying to keep my car "stock appearing", so I'm thinking of getting my 806 heads upgraded to a stage two head. (I'm thinking Patriot Performance)
I plan to have the heads milled for some increased compression...thus i'm not going with any aggressive lift to avoid ptv clearance and I don't want to have to have to check/change my springs often/ever.
It's mostly a weekend cruiser with some 1/8th mile drag racing a few times a year.
I'm thinking somewhere in the 224 or 228 range on the cam.
What do you think? What cam? Any other recommendations?
You have the basis for a great project. I'd send those castings to Advanced
Inductions or Total Engine Airflow for a basic CNC program which will breath
roughly 50-60 cfm more from your stock appearing castings. Either can mill
say .030 off for a bump to 10.7 ish compression w/stock head gaskets and
new TTY bolts. Get the appropriate length hardened pushrods for your cam,
an LS2 timing chain(only $40 uses your stock gears), and a new oil pump
pickup O-ring and balancer bolt. I'm pretty sure Texas Speed has a 224/228
cam thats like .581/.588 lift and will work well with PSI maxlife beehive
springs for excellant valvetrain longevity. Or for 25 bucks more an EPS
222/226 cam has had some great results lately. Good luck to ya
Thanks! Yeah, I plan to do the chain, oil pump, and push rods. I think I'm going with patriot performance for the head work...they are a lot cheaper.
This guy knows his stuff. Best advice. Go to advanced inductions. They are relatively cheap..($11-1200) for a AWESOME cnc porting program with proven results and they invest ALOT in r&d to keep making more power with cheap castings. EPS specs great cams. A XE-R or LSL Lobe. Something in the 224-228/232 range with around .600 lift would be a great cam. Has a nasty midrange punch and pulls hard to 6500 rpms. That's just my .02.
