Camshaft: '99 LS1 vs. '01 LS1
How much more power does the 98-00 cam make? Clearly it's only slightly more aggressive. Could you see this on a dyno or a track? And how do these two compare to the LS6 (listed below)?
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
2001 LS6 cam
207/217 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
116 LSA
Reason being: Does a '99 put down more power?
1998 - 2000 Fbody
116 LSA
2001 - 2002 Fbody
116 LSA
2001 LS6 cam
116 LSA
1998 - 2000 Fbody
116 LSA
2001 - 2002 Fbody
116 LSA
2001 LS6 cam
116 LSA
1998 - 2000 Fbody
116 LSA
2001 - 2002 Fbody
116 LSA
2001 LS6 cam
116 LSA
Internet Mechanic
1998 - 2000 Fbody
116 LSA
2001 - 2002 Fbody
116 LSA
1998 - 2000 Fbody
116 LSA
2001 - 2002 Fbody
116 LSA
As for power if you want to be accurate, with LS1 intake in 98-00 made less power then 01+ cars which is the reason why hp got the bump for the most part.
As for seeing it, maybe on a engine dyno. Probably if you kept the intake manifold the same but again its not that much of a change to make a real world difference.
Swapping any of the 98-02 F-body cams would be akin to rearranging deck chairs on the Titanic. Just not worth it. All else being equal the 98-00 cam would probably make a couple of more hp (I am talking less than 5). Swapping a LS6 intake onto a 98-00 car is vastly superior to changing a 01-02 car to a 98-00 cam.
A 99 would NOT put down more power. As stated above, the LS6 intake makes a difference. Also you have more restrictive stock exhaust manifolds on the 99. But if you take the manifolds out of the equation and did something funny like putting a 99 cam in an 02 ls1, yeah it would be faster.
A 224 cam, while it seems smallish compared to a lot of the cam guys use on here, isn't a small cam. You're moving up 24 degrees at .050 lift which is a lot for only 5.7 liters. If you go with a 112 lobe center, it will have a very noticible lumpy idle. Makes a lot more power upstairs too.
I've own both a 99 and 02, the 99 makes more power up high and the 02 makes more down low. I like the 02 better although I'm sure the 99 would win in a all out race. Another thing I noticed is the 02 EATS the rear tires up much faster than the 99. The 02 cam is much nicer for a daily driver IMO.
