Switching from 7.4 to 7.425 pushrod help
Switching pushrods from 7.40 to 7.425 I currently have the 1.7 yella terra rockers. If i do one set at a time will i have any problems? Any info before i get in a situation i cant fix would be appreciated, Thanks.
The push-rods length shouldn't effect the wipe pattern only the preload, shims are used to set the wipe pattern with the YT non-adjustable rockers.
FYI, if you change/re-adjust the wipe pattern with different shim heights it will change your pre-load.
