direction to go with cam??
So i'm looking to stall and cam at the same time. I've been reading most arent happy with the 3600 stall as its "not enough." I do plan on turning this into a primarily run track car so I was looking at either the yankSS4000 or the yankPT4000. With that being said, I would like to be around 400hp just for an idea for power. I understand i'll lose some power through the converter.
I've been doing reading and research on here about cams, but I still don't really know much about the numbers and what to look for. I know its going to have to be decently big. I'm at 335 right now, and the underdrive pulley still has to go on. Also, that 400 is going to be without heads, those will be after.
thanks guys
thanks guys
