LS1.. 427 Stroker build.?? - LS1TECH
Thread Tools Search this Thread
Old 08-15-2011, 08:33 PM   #1
Default LS1.. 427 Stroker build.??
Texas-speed.com sells a stroker kit for an ls1 stroked to a 427.. Im kind of stuck on purchasing it unless someone knows something I dont about going that big on a displacement kit. I also need help picking a set of head and cam package also. My goals are to build a motor to handle being procharged down the line. but I want like 550-600 rwhp on just motor.. I think with the motor being a 427 it should be fairly easy. correct me if I am wrong. The car will not b an every day car.. but if I wanted to drive it everyday.. i want the option to.. I know I will have to build my M6 trans a little. and when I procharge it. thats wen I plan on replacing the rear end with a 9 inch.. so i need opinions on the 427.. and head n cams suggestions for the 427.. thanks in advance
02M6TTOPZ28 is offline   Reply With Quote
Old 08-15-2011, 08:42 PM   #2
supersick99z's Avatar
The kit they sale will require your ls1 block to be resleeved I believe which cost a small fortune
supersick99z is offline   Reply With Quote
Old 08-15-2011, 09:22 PM   #3
Quote:
Well, the LS1 block is perhaps the best of all the LSx blocks.....so get it resleeved at a place like ERL or RED and go nuts with it. it'll be fine to 1,000 hp.
550 RWHP is a breeze with 427 cubic inches. That extra 50 to make 600 takes some good matching of the top end and cam.
If you'r going to procharge it.....I suggest only stroking the engine 4", maybe 4.1" max.....and about 4" bore. Let the procharger do the work and have a more reliable engine. 4" x 4" = 402ci....perfect for a procharger. 427ci is a bit big. If you want a little more cubes N/A....maybe do 4.1" bore x 4" stroke = 422ci. But the 402ci would be much better with the procharger.
You can still make close to 550 RWHP with a 402ci or 422ci.
LS6427 is offline   Reply With Quote
Old 08-15-2011, 09:40 PM   #4
bayer-z28's Avatar
^ I would think the LS6 block was better just because of the better bottom-end breathing with the "windows." And I've only recently learned that the LS1/6 blocks can be re-sleeved. Back before the LS3 came out (and even when the LS2 was still new,) we were stuck stroking the LS2 because the C5R block was the only other option for a larger bore.
bayer-z28 is offline   Reply With Quote
Old 08-15-2011, 09:50 PM   #5
Quote:
My LS6 block was resleeved back in 2002. I also had an LS1 resleeved before that from ARE.
I think it was Steve Darmijian of RED that told me the LS1 block is the strongest of them all.
Old 08-16-2011, 03:41 AM   #6
okay good, so let the pro charger do the work. Im gonna go out on a limb and ask how possible is it to get about 500rwhp with a ls1.. stock bore n stroke.. with a head and cam package?
Old 08-18-2011, 10:17 AM   #7
LS1TECH Sponsor
Jason 98 TA's Avatar
Give us a call & we will be happy to sit down & discuss a lot of options to get you what your looking for. You have to carefully select your components to get the desired power & dependability. It's best to discuss these options over the phone, and then we can build you a very detailed engine price quote.
Jason 98 TA is offline   Reply With Quote
Old 08-18-2011, 10:32 AM   #8
02blackbeauty19's Avatar
Yeah, Steve does believe that the LS1 block is the strongest because it has solid main webs with no cast in breather holes. It runs about $2,600ish for Steve at RED to sleeve it.
02blackbeauty19 is offline   Reply With Quote
Old 08-18-2011, 11:00 AM   #9
Kleeborp the Moderator™
MeentSS02's Avatar
Sleeve an LS1 and you'll be dealing with a wet sleeve, so you'll also need Evans coolant and their water pump. Not a huge deal, but it will add to the cost.
Last I checked, the LS1 couldn't be done with a dry sleeve like the LS2 can.
MeentSS02 is offline   Reply With Quote
Old 08-18-2011, 01:56 PM   #10
98_TA_EMLC's Avatar
i gotta ls1 block sitting in the shed I gotta do something with...I'm debating whether it's worth it to resleeve this or sell it and go to the ls2 for the infamous 454.
98_TA_EMLC is offline   Reply With Quote
Old 08-18-2011, 08:34 PM   #11
Just curious why this coolant and their pump would be necessary. Sleeves are cast iron.
COPO9560 is offline   Reply With Quote
Old 08-18-2011, 08:41 PM   #12
MeentSS02's Avatar
Quote:
Take a gander here:
427 cu.in. LS1/6 blocks with Darton MID sleeves
Old 08-18-2011, 11:34 PM   #13
It was done years ago with stock bore and stroke.......I think the old Morgan Motorsports did it with their Aggrressor 500 H/C kit.
But its not gonna be all that idle friendly.......lope from hell.
Old 08-20-2011, 11:13 AM   #14
You can get 500 whp from 346 ci pretty easy. Great cylinder heads, well picked cam specs, 13:1 CR, and meth/H2O injection will get you there. Or skip the meth injection and run E85, that works too.
If you want more, drop CR to 10:1, put a M122HH on top and it will make 600+whp thru a stalled auto trans with good street manors. That's close to 750 crank hp from "only" 346 ci. Of course, turbos or bigger blowers will do even more.
7008ccGTO is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
vengeance 427ci...... more info wanted!! Tuskyz28 Generation IV Internal Engine 40 01-04-2015 01:13 PM
lsx376 to a 427 stroker build, clearance question lo&sloSierra Generation IV Internal Engine 9 12-16-2010 03:07 PM
SPONSORS!!! I NEED Advice on my 427 NA build - Looking for 9's (Please Help) LT1Formula007 Generation IV Internal Engine 58 02-10-2010 10:54 PM
Which would you go with? An LS3 stroked to 427 or an LS7 azmusclecar Generation IV Internal Engine 10 01-13-2010 09:11 PM
Lsx 427 Chris'stransam Generation IV External Engine 10 03-17-2009 06:49 PM
Tags
427, 70, build, cubic, engine, ls1, lsx, lt1, make, motor, sale, specs, stroked, stroker, stroking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
