stock ls6 oil pump vs. ported
Old 08-21-2011, 05:10 PM
mjs1012's Avatar
Default stock ls6 oil pump vs. ported
im starting a build for my camaro and was wondering what the big differences between the stock and ported ls6 oil pumps are. is there a noticeable increase in oil psi?
Old 08-21-2011, 07:57 PM
RaVagE's Avatar
I'm not sure about the PSI increase, but the last pump I got with a port job, was a joke really. There is some excess metal where the pick up tube connects to the oil pump and thats the part that gets hacked down. I'm sure it helps FWIW.
Old 08-21-2011, 08:01 PM
Jimmy P's Avatar
I just used a new LS6 oil pump for my latest buid..No issues yet.
Old 08-21-2011, 08:53 PM
mjs1012's Avatar
ok cuz im doing all of this on a budget and i found a stock pump for a decently lower price and figured i could use the extra money that id spend on a ported one towards something else.
Old 08-21-2011, 09:44 PM
02blackbeauty19's Avatar
Why not use the LS4 pump? It was designed by GM to flow more oil with more Psi. They are cheap, too.
Old 08-21-2011, 09:46 PM
mjs1012's Avatar
cuz i never knew they were replacements for the ls1/6 lol
Old 08-21-2011, 09:53 PM
Look into it. I ordered one for my TT car and I know of others with very high HP cars running them.
Old 08-21-2011, 09:57 PM
mjs1012's Avatar
have you had any issues with it at all?
Old 08-21-2011, 10:13 PM
I haven't received it yet. It's supposedly in route to me.
Old 08-21-2011, 10:38 PM
01cherryreds10's Avatar
I put a used TSP LS6 pump in my car. 50psi on a cold start and it will go from around 43-60psi driving around. Seems to be worth maybe 5psi at the most IMO, not worth it for a street car at all. Maybe if the car was a little more serious I could see some benefits.
Old 08-22-2011, 04:20 AM
vettenuts's Avatar
There was a very good post a few years back and this pump was not recommended for a basically stock H/C motor.
I would go LS6 pump, and if you can't afford to port it don't worry about it. The pressure developed is determined by the bypass valve, which can be shimmed, but this isn't necessary either.
Old 08-22-2011, 04:43 AM
lemons12's Avatar
Stock ls6 will do you just fine.
Quick Reply: stock ls6 oil pump vs. ported
