Anyone use the COMP 978 springs?
Old 03-05-2004, 10:29 AM
Crowley's Avatar
Question Anyone use the COMP 978 springs?
This is from my other post .. suggest valvetrain (see below)
I talked with Jay and he said that the 978s should be good and I can use the stock lifters ... any had any issues? Remember this is for a daily driver ..
Suggest valvetrain parts for the following cam: (this is on a daily driver)
I figure I'll rev to 6800 - 7000
.232/.236 .595/.601 114+4
what springs etc do you recommend? These will be in Absolute Speed 5.3L stage II heads..
Old 03-05-2004, 11:37 AM
HOSS99's Avatar
Crowley,
For what it's worth Jay recommended 978's for his Absolute Speed 5.3L stage II heads
for a 230/230 .591/.591xer 114 + 4 cam that I ordered from him last week. We are probably in the same batch, keep me posted of when you get the heads and how they perform.
FYI - AP Engineering also recommended 978's with a 228/232 .600/.600 cam
I think we should be OK with those springs.
Thanks,
Old 03-05-2004, 01:32 PM
Crowley's Avatar
Originally Posted by HOSS99
Crowley,
Thanks,
I've read some posts on here that implied I could be in trouble with the 978's as well ... I have since talked with Jay and went to the 977 / COMPR setup. I will be sending him my cam so he can set the heads up without adjustable rockers (installing the correct pushrods I believe) ..
Since this is my daily driver .. I just wanted to make sure I wasn't on the limit of what my springs could handle ...
I'll keep you posted ... keep me posted as well ..
thanks,
Crowley
Old 03-05-2004, 03:44 PM
2001CamaroGuy's Avatar
I used 987s with my 2.08/1.60 valve heads and TR224/224 cam. I ran them for about 20K miles without any problems but in the last 5K I started noticing a lot of fall off in upper RPM. When I removed my heads this week, every intake valve had touched (slightly).
Doing it again, I would have used Comp R lifters and 977s in the first place.
Old 03-05-2004, 04:06 PM
Blktie8's Avatar
Default 978
I have the 978 for sale they are a bump above the 987 and a little less than the 977 I was going to run stock lifters with them.
Went with a head porters springs
The 978 and titainum retainers are still for sale.
They are new !
Old 03-08-2004, 09:59 AM
HOSS99's Avatar
Crowley,
After talking with Jay today, I also swithced to 977's. Now I need to by the Comp R lifters. Who are you buying your's from?
Bryan
