Texas-speed stg 3 ls6 heads and cam
Old 08-31-2011, 10:52 AM
02M6TTOPZ28's Avatar
Default Texas-speed stg 3 ls6 heads and cam
I hav a 02 M6 Z28, with the texas speed stg 3 ls6 heads with the MS3 cam 112 lsa.. can I expect at least 400rwhp?
Old 08-31-2011, 10:55 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
I assume you have at least a 4.00" bore short-block to run the Stage 3 heads? Also, you will have to have valve reliefs in your pistons to run that combo.
If you're running the stock LS1 short-block, the stage 2.5 LS6 heads are the ones to run, and we can set them up to clear the MS3 without valve reliefs in your pistons. So long as you are not running completely stock exhaust and intake, it will definitely make well over 400rwhp!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 08-31-2011, 10:58 AM
Ok, sounds like your the person I need to talk to.. so stg 2.5 with ms3 cam.. How streetable will that combo be? and what intake and exhaust would you recommend?
Old 08-31-2011, 11:00 AM
Street manners are somewhat relative, but many do daily drive that combo without issue. I guess I am getting old, because I find myself wanting the smaller camshafts in my car and better street manners and smoother idle characteristics every day
So yes, with the bolt-ons in place and a solid tune, it can be daily driven without issue. That 6 speed tranny helps with this as well.
__________________
badazz99ss's Avatar
you shouldnt have any problem making 400 with that combo. I made 393rwhp with the ms3 cam only with stock heads and ls6 intake and full exhaust, 6spd
Old 08-31-2011, 11:01 AM
Is it possible to get the intake I have ported and polished? as far sa exhaust I could run full length into a y pipe with a cut out. and dump it after the mufflers
Old 08-31-2011, 11:18 AM
What size intake would you recommend?
Old 08-31-2011, 06:03 PM
Floorman279's Avatar
pick up an ls6 for like 250 bucks......with the stage 2.5 heads, ms3, long tubes and an ls6 intake you should be right around 440-450 rwhp
Old 08-31-2011, 09:43 PM
Matt 00' T/A's Avatar
+1 to the 2.5 LS6 Heads/MS3 cam combo! I have Stage 1 LS6 Heads and 220/224 cam, with supporting mods and put down 408whp/378wtq.
Old 08-31-2011, 10:05 PM
Mazzenger's Avatar
MS3 is my favorite cam to date that I have run in my car.
Old 09-01-2011, 12:43 AM
Correct me if I am wrong... but didnt 01 and 02 SS and Z28 come stock with an LS6 Intake??
Old 09-01-2011, 12:52 AM
lemons12's Avatar
Yes.
You are all over the board. Research your exhaust, then research your intake, etc etc..
Old 09-01-2011, 12:09 PM
Originally Posted by lemons12
Yes.
All over the board?? You mean I have too many post? or Im jumping off topic?
Old 09-01-2011, 03:10 PM
lemons12's Avatar
You need to narrow you options down one by one and research each individually.
Look into exhaust.. Then intake... Then cam... Etc etc.. You will have a much more well thought out better running combo.
Old 09-02-2011, 10:53 PM
HTX
HTX's Avatar
What lemons said.. or if you don't care to research just call TSP and give them you r credit card.
Old 09-02-2011, 11:11 PM
01ssreda4's Avatar
With the proper intake and exhaust, this combo should do 450 at the wheels in an M6 without issue.
Quick Reply: Texas-speed stg 3 ls6 heads and cam
