Help! Crank only turns 180°
Old 08-31-2011, 02:35 PM
JeremyKrauss's Avatar
Default Help! Crank only turns 180°
So after several months, my mechanic has finally finished preparing my 02 z28. It arrived with the heads on, but lots needed to be done. He pre lubed it today and when he went to turn the crank manually , it only turns 180° in either direction before it locks up. what would cause this?
Old 08-31-2011, 02:36 PM
Jackus's Avatar
Possibly rod clearance issues.
Old 08-31-2011, 02:38 PM
Darkman's Avatar
Ask your mechanic how he (she) assembled the valve train with that limitation?
He says it turns smoothly right up until it stops.
Old 08-31-2011, 02:43 PM
parks450's Avatar
did he check PTV clearance? Would almost bet thats your problem if its not stock.
Old 08-31-2011, 02:46 PM
The guy I bought it from said it's all stock.
Old 08-31-2011, 02:53 PM
ss1129's Avatar
You're guy number 2 that this is has happend to this week. Hes having rods hit his cam, or so they think.
Old 08-31-2011, 02:58 PM
Jackus's Avatar
I dont see how the rods could be hitting his cam..
Old 08-31-2011, 03:08 PM
ss1129's Avatar
Thats what I said, unless they have a stroker crank in there?
Old 08-31-2011, 03:22 PM
Jackus's Avatar
No, the cylinder wall would be in the way.
Old 08-31-2011, 03:46 PM
I was told it's all stock except for some (used) yellow ls6 springs.
Old 08-31-2011, 03:58 PM
t-1
t-1's Avatar
The cam gear and the crank gear for timing, are COMPLETELY incorrectly installed. My car did this but it was because a 4 in crank doesnt clear a Canton oil pan with out a little love.
Old 08-31-2011, 04:08 PM
So how should I go about verifying and correcting this?
Old 08-31-2011, 04:22 PM
andrewdruiz's Avatar
Same thing happening to me, 180 degrees each way, won't fully rotate. I'll let you know what happens with my setup once my builder gets back to me.
Old 08-31-2011, 07:57 PM
FASTFATBOY's Avatar
Make sure you dont have a pushrod sitting on the edge of the lifter, I had this happen and made me look like a dumbass for about an hour on my LT1.
The valve is opening very early because the pushrod is too long because its not sitting down in its cup in the lifter.
Look at the pushrod it will look slightly crooked, you can look straight down the pushrod with a flashlight.
Old 09-01-2011, 03:58 PM
no, it's not the pushrods, it still does this when we took all the rocker arms off. the crank rotates a little bit, and then it's like it hits a solid object. turn it the other way, and same thing.
my builder is going to pull the heads and see what happened.
Old 09-01-2011, 04:32 PM
TurboBuick6's Avatar
A different engine builder who knows what he is doing?
Old 09-01-2011, 04:50 PM
FASTFATBOY's Avatar
Pulling the heads won't tell you anything, pull the pan.
Old 09-01-2011, 06:06 PM
LilJayV10's Avatar
LMAO. Sorry but that was funny. That's like saying falling isn't bad it's the sudden stop at the end.
Is the car an auto? I have seem people not tighten the torque converter bolts up and they hit inside the bellhousing.
Old 09-01-2011, 06:32 PM
blue by you's Avatar
Pistons on rods backwards?...don't ask me how I know this....
Quick Reply: Help! Crank only turns 180°
