Whats HP should I expect? Cam Swap 224/224 to a 227/229
Old 03-05-2004, 06:01 PM
SuperSlowSSLS1's Avatar
Default Whats HP should I expect? Cam Swap 224/224 to a 227/229
Ok I will be changing my cam next week I curently have a
224/224/581/581/112
This is what Iam going with
FMS 227/229/576/596/113+3
How much HP do you think that I will gain from this cam??
Iam curently also runing TEA 1.5 heads..,And FLP LT
Any help would be great.
thanks..
Old 03-05-2004, 06:31 PM
z98
z98's Avatar
10 maybe. There was a picture of a graph comparing 3 cams of similar spec, the difference between the 224 and the biggest one was like 10 rwhp.
Someone will probably post that in a bit
Old 03-05-2004, 06:45 PM
2001 Red Coupe Bandit's Avatar
I went from a 224/224 .563/.563 114LSA +4 to a
228/228 .588/.588 114 LSA +4
I gained about 12 rwhp
Old 03-05-2004, 06:52 PM
BigTex's Avatar
You wouldn't have a dyno overlay pic showing both cams would you? I'd like to see lower end power and under peak numbers.
Old 03-05-2004, 07:37 PM
98SS Blackattack's Avatar
FMS cams rock so i would say 15.
Old 03-05-2004, 07:44 PM
mikemodano9c's Avatar
224/224/581/581/112
thanks..
sorry to say it...but i dont think it's even worth swapping...
get something bigger if you want to upgrade
you might gain 10rw...but you will actually loose low end with less lift and bigger duration...
Old 03-05-2004, 07:58 PM
How much low end power am I going to be looseing?
Old 03-05-2004, 08:36 PM
Josh's Avatar
I wouldn't expect more than 10 peak horsepower. From what I've seen, though, it doesn't take a huge FMS cam to make really awesome power. I believe the FMS 230/232 made over 400 RWHP recently on a car without an ASP pulley through a GMMG.
Good luck!
Josh
Old 03-05-2004, 08:47 PM
BLUEBYU's Avatar
I like the specs...I have a TR224 also and have considered swapping for a "larger" setup. I had considered a 228/232/580's lift (113+3), but like the current driveability and low end umph. Of course next week I may change my mind...
Old 03-05-2004, 11:15 PM
you won't loose much, but you will have to rev that cam higher than your previous to see any benefit from it...
my reasoning would be...
you old cam was lower duration, higher lift, tigther lsa...it surely made good midrange with pretty decent top end power probably topping out ~6500 rpm
your new cam with more duration, lower lift, on a higher lsa...it has a little more potential to make better upper rpm power, but will need to be spun a little higher to even see it...it would probably max out on stock heads around 6600-6500 and the peak shift point would probably be ~6700 rpm.
all in all...if you want more performance...
if you want to shift ~6600 rpm get something like a 230/230 .58X 58X 112 lsa...or...
lower lsa should make more midrange and also keep your peak power lower in the rpm range so you dont have to spin the motor as high...
if you want my opinion if you are running tea 1.5's...
get something along the lines of tsp's 231/237 if your springs are capable...
its a 231/237 .59X .59X 112 lsa...it would take advantage of your heads more than either of those cams...
i have a 228/230 .571 .573 112+2 comp cam i have for sale, but in all honesty if you can go bigger with ported heads i would do so...don't waiste what you paid for!
Old 03-06-2004, 01:42 AM
So what ur saying is that Iam gonna loose some more lowend and midrange power.
correct?
But gain more on the high end??
With the lobe being 113+3 is the caming going to sound alot different?
Here the cam more? Or not at much?
And well so I schould expect a 10 to 15HP increase correct?
Old 03-06-2004, 02:41 AM
jrp
SN95 Director
jrp's Avatar
the way these FMS cams have been lately you might only gain 10-12 peak rwhp but i'd wager you'd pick up alot of under the curve power, especially with those TEA heads. TEA/FMS seems to be a bread and butter combo.
Old 03-06-2004, 12:49 PM
So if iam now shifting at 6200 and well I can go all the way to 6500 now what will this prob change to>?
Old 03-07-2004, 03:36 PM
Will I gain at least 15Hp with this cam..
Old 03-07-2004, 08:00 PM
Terry Burger's Avatar
You might get 5rwhp, might get 10rwhp, you might lose power. I don't think its really worth it unless you really like working on the car.
