Need help identifying these rockers and springs *LS newbie*
Old 09-05-2011, 04:17 AM
asinapple8805's Avatar
Default Need help identifying these rockers and springs *LS newbie*
The rockers are Harland Sharp, but how would I know if they are adjustable or not, and how would I know what specs they are? 1.7? 1.8?
Also, can anyone identify the springs?
Thanks for your help!
Old 09-05-2011, 04:31 AM
chrisfrost's Avatar
The springs appear to be LS6 yellow stock springs . As far as the rockers , You may need to remove 1 and locate the part # to know what exactly they are . As far as the rockers being adjustable , it's not likely as the LS engines use non-adjustable valve trains with the exception that You adjust for cam changes by way of different length p-rods in .025" increments .
Old 09-05-2011, 05:28 AM
01ssreda4's Avatar
Pretty sure they make adjustable roller rockers for these motors.
Old 09-05-2011, 06:31 AM
raven154's Avatar
They do make adjustable rockers as I have some on my LS6; however, these do not appear to be adjustable and they also look like Harland Sharp rockers.
Old 09-05-2011, 08:08 AM
Thanks for the replys.
so it is confirmed that these are stock LS6 springs?
that's the main question i had. Thanks
Old 09-05-2011, 08:12 AM
01ssreda4's Avatar
Yep, should be good to .550 lift.
Old 09-05-2011, 09:04 AM
raven154's Avatar
What he said^^^
Old 09-05-2011, 10:04 AM
supersick99z's Avatar
The Harland Sharp's should have a part # on them. About 3 letters and 2 numbers. The numbers will either be 17 for 1.7 ratio or 18 for 1.8 ratio.
Old 09-05-2011, 10:48 AM
JS01's Avatar
Not adjustable. If they were they'd have an adjuster and jam nut above the pushrod cup.
JS01's Avatar
They do.
Old 09-07-2011, 02:36 PM
again, thanks a lot for the replies.
