stroker, rods hiting windage tray.
building my stroker and putting the acc. on and the rods are hitting the windage tray what have yall done? new tray or space with washers? any ideas?
Moderator
Just clean the pickup, put tape over it, then put two 1" cubes of a soft clay or Play-Doh on each end of the taped up pickup. Wet the cubes with oil or water, and then place the pan on the engine with the gasket.
When you take the pan off, the oil should keep the cubes from sticking so you can measure the height of the flattened cubes to see how much clearance you have.
Like KCS said just recheck when you are through and make it right. We use two to three 3/8 washers on the windage trays on mosty stroker deals every day or so and you usually do have to check the pickup height to make sure it isn't bottomed out in the pan.
ok ended up with three washers and now my pickup is to close to the pan, looking for options from the pros. i thought about haking up the widage tray to were i can get the pickup tube under it in the spots it bolts up, anyone?
haha sounds good, but the dealers around here are a joke couldnt even find me the countersunk bolts for cam retainer plate.
