Help With Rocker Arms
Old 09-10-2011, 09:26 PM
brian_king25's Avatar
Default Help With Rocker Arms
I have read that the best for my application are the stock arms with the bearing fix but have to ask!
Set up is as follows:
402 Iron Block
Thunder Racing heads
Current 1.7 scorpion roller rockers (THey hit the stock valve covers BAD)
F1A Procharger
15 LBS Of BOOst!
What will wortk the best and where do I get them?
I know Texas speed sells a set of new Factory Rockers with the Comp FIX but can I get them any where else or should I get something different?
Old 09-10-2011, 09:50 PM
Darkman's Avatar
The factory rockers with the bearing upgrade is a good choice in that it is strong and relatively lightweight. If you want to use the more expensive roller rockers you should look Yella Terras or Crane Golds.
