Heres My Build.... should a do a bigger MAF sensor now before tune or is stock fine??
Old 09-12-2011, 03:55 PM
Imperial's Avatar
Default Heres My Build.... should a do a bigger MAF sensor now before tune or is stock fine??
Mods are as followed, Im needing to know if I should get a 100mm TSP MAF sensor and will it make any power, or will the stock z06 85MM MAF be fine? Also, will a vararam air bridge get me any gains with my setup? I want to cover all the basis before I have Tom Wong tune it for me. Any guess on what il be making power wise!?
PRC stg 2.5 heads ported and polished, PRC titanium dual valve springs, seals, retainers etc, 7.375 push rods, ls7 lifters, comp rocker trunion upgrade, comp cams LSR 231 239 on 113 lsa, FAST 102mm lsxr intake manifold, nick williams 102mm ported and polished throttle body, FAST ls2 style billet fuel rail, FAST 36lb injectors, ported and shimmed oil pump, SLP undriven crank pulley, american racing longtube headers, catless, x-pipe, b&b exhaust, vararam intake (stock airbrige), 160 degree thermostat, ls2 chain, all new gaskets, Monster stage 3 clutch and flywheel...
Quick vid of the car after we put it together and did a quick drive in it to the gas station... http://www.youtube.com/watch?v=1e98qmsD_lk
Old 09-12-2011, 04:34 PM
99LSS1's Avatar
85 should be good. That is what I am running on my 402 with a Fast toys 85mm Lid. Also a 90/90 Fast.
Old 09-12-2011, 04:58 PM
Imperial's Avatar
also any guess on what ill be making power wise?
Old 09-12-2011, 05:42 PM
ryanzcastro's Avatar
Im looking forward to seeing your numbers. When are you getting it tuned?
Old 09-12-2011, 08:17 PM
SOMbitch's Avatar
If it is worth say 5hp to you then then yes.....Maybe worth a few more if you plan on a 102/102 down the road.....
Old 09-13-2011, 01:19 PM
Imperial's Avatar
I do have a fast 102/102 tb - read mods!
Imperial's Avatar
on the 23rd of this month!
Old 09-13-2011, 03:13 PM
LS1-450's Avatar
85mm MAF is fine. Nice mods. Take 'er easy until she's been tuned.
Old 09-13-2011, 08:22 PM
99LSS1's Avatar
Sounds good. TJ will treat you right!!!!
Old 09-13-2011, 09:59 PM
SOMbitch's Avatar
Well then why do you want to bottleneck it with a baby maf?? Especially if a you decide on a good performing intake like vararam!!
Old 09-14-2011, 12:04 PM
Imperial's Avatar
I also have a vararam....lol from what I hear bigger is not always better with the MAF, something about air volume vs air something idk
Old 09-15-2011, 01:29 PM
Imperial's Avatar
so thats 2 votes for 85 and 1 for the 100 maf? any others?
Old 09-15-2011, 01:42 PM
SpinsB's Avatar
100mm tsp maf vote. get ride of the bottle neck
Old 09-15-2011, 04:16 PM
bluess57's Avatar
Get a SD tune and go without a MAF
Quick Reply: Heres My Build.... should a do a bigger MAF sensor now before tune or is stock fine??
