Check out my cam bearings (PICS)
Old 09-15-2011, 06:41 PM
02blackbeauty19's Avatar
Default Check out my cam bearings (PICS)
I've been fighting a low oil pressure issue EXACTLY like this guy has outlined in this thread:
https://ls1tech.com/forums/generatio...c-pursuit.html
I was able to pull my camshaft out today and use my video scope to snap some pictures of each bearing. They are not GREAT quality, but you can see how they sit in the cam bore.
I mainly took the pictures to see if any of the bearings were walking forward or backwards as opposed to the bearing surfaces.
I'd like to know what you experienced guys think about these pictures.
I'll also add that the cam had no problems coming out and all the bearing holes seem to still be lines up with the oil holes in the block.
Starting from the front and working back...
1)
The first picture that was taken with my real camera shows some markings, but I can't feel any scratches our anything with my finger.
2)
3)
4)
5)
Old 09-15-2011, 07:32 PM
JS01's Avatar
From what I can gather from these pics, your cam bearings seem to be in good condition. You would be very surprised as to how bad a cam bearing can 'look' at still be in great functional order. Really as long as the bearing is in the housing bore square and with proper press and of the proper ID that covers 90% of things.
Old 09-15-2011, 08:34 PM
That's kind of what I was thinking, but I definitely welcome input from you and others.
Look forward from hearing more opinions and advice.
Old 09-15-2011, 08:45 PM
lt1pwr1's Avatar
Agreed. They look nearly new with no copper showing or so it seems judging by the pics.
Old 09-15-2011, 10:28 PM
Yeah, I didn't see any signs of copper whatsoever. The pictures I uploaded here seem worse than what I could see on the boroscope screen, but I'm not sure why. I was mainly concerned with walking of the bearings like the guy posted in the thread I linked in my first post. I truly don't think any of them are spinning as the oil holes seem to all be lined up.
Is it normal for the front cam bearing to be flush with the front of the motor?
Old 09-15-2011, 11:38 PM
01ssreda4's Avatar
Another thing to consider is the condition of the cam journals where they ride on the bearings. I would think if the cam is slick, then the bearings are in good shape.
Old 09-16-2011, 04:41 AM
O2Form's Avatar
If the oil holes are properly aligned how could you be losing oil pressure? You could check the cam bearing journals with a mic and check your bearing clearances.
Old 09-16-2011, 06:48 AM
There are multiple ways an engine can lose oil pressure. It doesn't have to be the came bearings.
Old 09-16-2011, 06:59 AM
And yes, That is the first thing I looked at before I put the scope to use. The cam journals are seemingly flawless.
Old 09-16-2011, 07:32 AM
O2Form's Avatar
really? are ya sure?
Old 09-16-2011, 08:00 AM
Yes, I am.
Old 09-16-2011, 08:01 AM
NXZ28's Avatar
Mine looked similar but I couldn't see the #4 and #5 bearing. When I pulled the engine the #5 oil hole was clogged with bearing material.
Old 09-16-2011, 12:41 PM
Did you have the same oil pressure issue described in my linked thread?
Old 09-16-2011, 12:48 PM
Z284U2TRY's Avatar
How many miles on those bearings?
How does the cam look?
Old 09-16-2011, 12:55 PM
The cam looks brand new and I'm not really sure of the milage. The motor has been in the car about 4 years so if I had to guess, probably 30k or so? I have it written down somewhere, though.
Old 09-16-2011, 01:06 PM
NXZ28's Avatar
I noticed my hot oil pressure at idle kept dropping. I can't measure it in miles because I don't street drive my car.
Quick Reply: Check out my cam bearings (PICS)
