Cam position sensor, how to change??
Old 03-07-2004, 03:27 PM
Steve98Z's Avatar
Default Cam position sensor, how to change??
I have heard you have to pull the intake to get to the cam position sensor, is this true?
Old 03-07-2004, 03:41 PM
chino_man279's Avatar
If I recall correctly, the cam position sensor is at the very back of the motor on the top. With the motor in the car, you would definately have to pull the intake out to get to it. There is one 10 mm bolt holding it in place I believe.
Old 03-08-2004, 06:15 AM
Steve98Z's Avatar
Ttt???
Old 03-08-2004, 08:47 AM
CHRISPY's Avatar
Yep pull the intake and it is right at the back. Easy as pie to change. (I changed mine in about half an hour in a parking lot )
